Help identifying this motor?
Suprathepeg
A buddy gave me an even rude power head with midsection etc but it has no fear case or cowling. I'd like to figure out the hp and year but I can't make sense of the serial number. Can anyone shed some light on this?
175se
Unless my eyes are failing me,it appears to be electric commercial-manual tilt, long shaft, 1994 model yr.
Suprathepeg
Reason I ask is that I have a line on a 1996 70hp with a blown power head If this power head is good can I just swap it over?
Faztbullet
Should be a direct bolt on, just use your carbs. Check it for compression before doing any work.
Suprathepeg
What is the difference between this motor and a 1979 Johnson 70hp motor?
flyingscott
The 79 motor is 49 cid the 94 is 56 cid different motors do not know if they interchange.
oldboat1
could explore using your '96 lower unit on the '94, if the '94 is otherwise complete. Not saying that would work -- but if compatible, would presumably be a simple switch. Easy way to try out the donor powerhead, and get in a little fun too.
edit. Ah, see the '96 is not in hand -- but guess option might still exist.
The 49 cube engine DOES NOT interchange with the 56 cube model.
