1999 johnson 150 ocean pro cranking issues
medicman51
I am having starting issues. batteries fully charged including jumper cables attached to attempt to start. All batteries connections changed and battery posts cleaned. 12.6 volts to start down to 10-11 when starting. engine "sounds like" it is not getting enough to crank over. Like it needs more power. when I hook jumper to starter she is rough to crank over then takes off and cranks.
10-11 volts while cranking is a bit higher than expected. Normally one wants no less than 8.5V when cranking, and that is usually about what you see. Not sure why your voltage is so high. Maybe your batteries are very strong or your starter has an open winding, or the voltmeter is inaccurate.
Do you see any burning of the cables or other forms of heat on the cables? Heat indicates resistance and you want the lowest resistance you can get.
jerryjerry05
Pull the plugs and do a compression test.
All plugs need to be out when doing the test.
Check ok? Then rebuild the starter.
Check all the grounds and inspect the cable for weak spots.
Load test the battery.
Use a hygrometer and check the individual cells.
All else fails?
Drop the lower unit and see if that makes a difference????
Sometimes a seized bearing will make it do that.
Fed
Measure the voltage between the starter motor positive stud & the starter motor case when the key is turned to the start position, you will get a big surprise.
medicman51
Ok did compression check seems to crank over better measured both sides of starter. 12.6 to start across starter. drops down to 9.3 on starter during cranking when I start sometimes it boggs down when cranking then cranks normal. cleaned terminals on starter. no to little improvement at times when starting you can hear solenoid then fires over. is there a way to check the starter?
medicman51
If I drop the lower unit where am I looking for a lower unit bearing that may be seized? I did run into sand and suck up sand into the water pump . it over heated. after a good flush all sand out and engine ran fine. test run multiple times after and it ran but hard to start.
OK, 9.3V when cranking is fine. Remove the spark plugs and turn the motor by hand, and feel for any binding. The crankcase will have some compression, so some resistance, but you should be able to separate that from a bad bearing feel. Also cranking with the spark plugs removed, you should hear the motor turn smoothly and with a predictable steady speed.
Fed
My bendix slipped internally for a split second but just enough to make it feel like there was something else wrong.
My starter motor voltage was fine so I stripped the starter which was a waste of time as it was also fine.
I finished up marking the bendix as you would mark a prop for a slipping hub to find it.
I'm sure there's a better way to check for a bendix slipping more than it should, maybe a mythbuster's high speed camera. LOL
oldboat1
What were the compression numbers?
