Ficht knocking sound
tristram
Hello. I have recently brought a 2003 FICHT 225HOFHLSNF. The engine has started making a knocking sound similar to an outboard not quite in gear. The motor had been run hard and seriously jolted in the sea for nearly an hour then slowed and idled for 5min+. Upon restart the knocking started so we ran at idle for about two miles back.
I have tested compression, all similar.
Can this be drive or gearbox related. If so is there an easy diagnosis so it can be eliminated.
A mechanic has suggested engine bearings. (This is what I am expecting)
Are there other possibilities.?
I would be very grateful of any advise, warnings or tips from anyone with experience pulling down a similar motor. The cable and manual are on there way. I have a mechanic to assist me but this will be my first time.
sutor623
Does it go into gear? Or is it actually slipping teeth in the lower unit?
First thing that I would do is pull the lower unit and then run a water hose with adapter (so it fits) onto the water intake line on the outboard, start her up and let her idle. See if the knock goes away. If it does, then it is an issue in the lower unit. (More than likely a main lower unit bearing.) If you still have the knock with the gearcase off, unfortunately it is coming from the powerhead.
So, short answer, may be coming from lower unit.
tristram
No change in knock with gear engagement and no perceived slippage. I will go a head and take lower unit off. I am still going to expect power head but any experiences you might have had with lower units I would love to hear. Thanks
Bosunsmate
I agree with Pete above. I just take the connector off my garden hose and it just slips on most motors i do that to, sometimes a zip tie helps but if you put the hose up the tube far enough it normally holds fine. Just dont turn the hose up to too higher pressure, just keep it at a gentle stream.
You could also inspect your lower unit fluid for metal fragments, if it has magnets on the drain plugs you can check those too.
sutor623
If one of the main driveshaft bearings in the gearcase is gone then you won't notice a difference in and out of gear because it is always spinning. And like Bos said you can check for chunks in the gearcase before even bothering. We'll keep our fingers crossed for ya.
tristram
Many thanks for the advice(and support). My off the clock mechanic tells me the gear case will have to come off first any way so I will post the results asap. Can anyone offer advise on gear case bearings or other items that might be needed
sutor623
Tell us what ya find and we'll go from there. No need to mentally start rebuilding a gearcase if that's not the issue.
Bosunsmate
Theres a few bearings, they should all be available; the seals will probably need doing too. Check if your gearcase oil is milky as that indicates that water had got in
