jamespjackson95
Thread starter- Joined
- Jan 21, 2012
- 30
Okay guys I can't seem to solve my overheat problem. I have a 1996 bayliner ski challenger with a 5.7 carbed Mercruiser. This boat is an inboard V-drive... After taking the boat out for the first time it ran great... Rode around at all speeds for numerous hours with no problems. Boat ran 170-175ish(right in the middle of my temp gauge). We decided to surf and loaded up about 2k lbs of ballast... We surfed for a few hours with no problems until..... Randomly while wake surfing the boat exhaust started to sound noticably louder (like the boat was running at a higher rpm).... Also there was more white exhaust smoke or steam coming out of the exhaust.... Then we noticed the gauge started warming up and near 200 we slowed down to an idle and it cooled off... Tried to start surfing again and it would immediately do the same thing (sound louder and then warm up)... That ended the day
I went home and checked the transmission cooler and found nothing, checked the Walter v drive for blockage and found nothing... Checked the water pump impeller and it looked fine. No missing blades(owner just replaced it).
The next day we went out to surf and all was fine for multiple hours. Then randomly started getting louder and overheating. At idle it would cool back down. I decide to pull the thermostat and it looked fine... With it out of the boat it ran 100 degrees and we continued to surf the rest of the day with no problems and ride around at all speeds with no problems. (Great I thought I found the problem)
The next day the boat ran 100 degrees for about an hour or so while surfing then just randomly the exhaust sound got louder and the temp gauge rose and we slowed down to idle and it cooled off... Tried to surf a couple more times immediately after that and everytime within about 30 seconds it would start to overheat... Then we pumped the ballast out and just tried to head back. Anything above about 5 mph would cause the boat to warm up... We tried 5 or so times and everytime it would warm up... But slow down to idle and it would drop back to 100...
So today I decide to pull the impeller and its brand new (I'm gonna replace it anyways). Also while the boat is in the water the hose coming from the impeller has 5-6inches of head(or water shooting straight up when removed... So good water going in). I pulled both of the risers off and they both looked pretty good. No major rust and no clog that I can see (although I didn't yet take the manifolds off). One of the down pipes looks like it had once got pretty hot and melted causing some restriction but hardly any for a 4" pipe. Just wanting some ideas of where to go next with this. See pics. I have checked all of the hoses and all seem to be fine with no bends or clog gage when running water though it. I am ordering a new thermostat(140) and a new thermostat sleeve and also new riser gaskets...
I have verified with an IR gun that the boat is actually overheating. Sorry for the long post. Just don't know what to do next.
