1977 evinrude 9.9 wont start
mcody613
I have a 1977 evidrude 9.9 that wont start, here is what it has/what is new
9.9 with electric and pull start
10755a
- new plugs
- rebuild carb
- new pump and gasket
- has spark, 1/4
- getting fuel to cylinders
- good compression 100psi both cylinders
- wont run on fuel or fogging oil right into the carb or head
what am i missing here, it should atleast give some hope shouldnt it
Flywheel key sheared.-----------Possible problem with reed valves.----Plug wires reversed ?
mcody613
plug wires seem correct, one wont reach the other
i just inspected the flywheel key looks good
how do i check the reeds
Were coils removed and perhaps installed in the wrong place ??
mcody613
well i put everything back together and now it starts but only when i have the fuel tank disconnected, when i connect it, it will die in no longer than a minute
To me where i sit it is obvious it is flooding via a bad float valve or ruptured diaphragm in the pump.---And yes I see that you have a new pump.
No, inspect / test and see what is wrong first.----Does the primer bulb go hard ???
OptsyEagle
Pump up the primer bulb. Restart the motor. Does the motor stay running if you pump the primer bulb just before it dies or keep pumping it every 10 seconds or so?
mcody613
If I pump the primer and try and start it it won't start. I have to disconnect it and keep trying to start it. Like the carb is getting flooded
oldboat1
top coil (top cylinder) would have a blue striped wire, bottom coil would have a green stripe. Think they could be installed incorrectly, as indicated. Suggest checking.
also, possible your fuel mix isn't right. Referenced trying to start on fogging oil (pop, maybe, but probably wouldn't run). Check for fouled plugs -- clean and regap. Then run on clean 50:1 or whatever the mfg. recommendation is for that particular motor. Clean/functioning tank/lines/hand pump.
mcody613
Plugs are new. Tank is new with 50:1. It runs great now once I disconnect the tank and crank until fuel stops coming out of the hole on the top left of the carb (looking from intake)
AlTn
on the carb rebuild...is the float installed properly?...tab on float arm should point towards the carb body not the float bowl
oldboat1
might not be the float itself (but sure could be) -- would look to cleaning the float valve, though, and probably replacing the needle. Just get an appropriate kit -- one with a new float if you can, but can work with the old one. Point is to thoroughly disassemble and soak everything in there (metal parts, anyway), then clean them with compressed air, carb cleaner spray, a small wire. It's not unusual to have to do it a couple of times. Need to open up the fitting on top, and clean out that area (idle system). Any blockage in vent holes can also do it in.
OptsyEagle
I believe that hole is the carb's vent. Definitely gas should not be coming out of there and your float should have shut the gas off long before that event happened. Your float is not working. You will need to take the carb apart and figure out why.
