- Apr 17, 2002
- 71,444
Re: 350 SBC Vortec Conversion
Ayuh,... You're Learning something........<br /><br />Now you've got to get Off the compression Ratio issue.......<br />The Vortecs can be run with considerably More than the old heads,.... Without High Test Gas.....<br />With the semi-dished pistons you Have,... You'll be lucky to get the Comp. Ratio Up to where the Maximum Potential can be achived,.....<br />You'll be running Better,+ Stronger,..... But, There'll Still be more Possible Power with Lower end changes.......<br />
Not necessary, Nor recommended,......<br />Although the vortecs Do use a Self-Guided Rocker,.. It's still a 1.5 ratio.... <br />What about going to 1.6:1 rockers?
As I said before,... You'll need to measure how Deep the piston sit at TDC, below the Block Deck..........<br />Then find the Fel-Pro gasket that gets you as Close as Possible to the Golden .040 Quench............<br />If the Block Hasn't been Decked,.. I'm Guessing that you'll be using a Shim Gasket..........Which will be No Problem with your Closed Cooling System.............<br /><br />Go back to that Google search,.... All the answers are There........Which head gasket should I use?
