Question on 1973 Evinrude 9.5hp
bpike
I have this old Evinrude in the shop, and the mechanic is telling me that it needs a new prop, because the prop bushing is out. He says this is a rubber piece inside the prop. He is telling me that this acts as a "shock absorber" of sorts. I was under the impression that the prop was just solid. Is my outboard mechanic feeding me a line similar to "Muffler Bearings" to sell me a new prop, or is this a legit problem?
F_R
No Title
He knows what he is talking about. There IS a rubber bushing in there, you just can't see it without sawing it in half--as I did this one:
flyingscott
Sounds like a mechanic to keep I've seen guys rebuild a lower unit for the same problem.
bpike
Thanks guys, just know that what he is doing to get this old thing up to shape is gonna set me back somewhere in the neighborhood of $400 (Prop isn't the only thing he's fixing). Only reason I'm willing to spend this much is cause the thing starts like butter even when cold, a 5 year old could start it, if he knew what the choke was. Still hurts to fork over that kinda cash on a motor that is better than 40 years old.
Sascwatch
The 9.5 evinrudes were the first motor I ever tinkered with. I've got one that once warmed up will start by spinning the flywheel with the palm of your hands. Evinrude dealer told me this and I just had to try it for myself, worked first try. Awesome motors for sure.
interalian
We had a '73 9-1/2 when I was little. Another identical boat had a later 9.9 and my boat was always faster. Probably didn't hurt that I was 50 pounds lighter than my friend...
F_R
Yeah, I used to do that when demonstrating a motor for a prospective buyer. But I WARNED them not to try it themselves. Big chance of getting your fingers caught between the flywheel and starter pinion. I hate it when that happens. BTW, I sawed that prop open because nobody would believe me either.
