Issues with '94 johnson 120hp
Eyegouger
Just purchased boat and only heard it run with muffs. First mistake... took it on water last weekend and after a bit to get it started, got it out on the lake for a run. Ran rough from the idle and while in gear. Replaced primer bulb, had carbs redone and pretty much same results. Compression is at 90 across board. Messed with carb settings some and took it back out next day. Idle still rough, dies out when going into gear unless u do it real quick and give it throttle. Alarm came on twice while out and pulled throttle back down and it shut off both times. I have a stream coming out but it seams to be somewhat restricted because of the fitting that it flows through. When I pull the hose off it has a nice pee stream thru the hose.
Put motor back into gear after about 5 min. and ran ok for a short time then started chugging and running rough again. Kicked throttle back down but couldn't get over 4000 rpm without it chugging and spittin.
That was Saturday.
Added sea foam to gas and some Lucas octane boost to gas. Previous owner replaced water pump and impelor last season.
Now on sunday took outand ran it to see if additives would help and it actually ran better. No alarm sounded. I'm puzzled. Keeping my fingers crossed for next trip. Any feedback on the compression readings. Is 90 across the board low?
Thanx .
Barnacle_Bill
90 might be a little low but it could just be the gauge. The important thing is all the cylinders are even and no variation in compression..
batman99
Being new (new to you) engine with unknown real history of this engine, it might be best to call a few boat mechanics in your area and ask them to give it a professional tune-up. During tune-up, they also check cylinder PSI, check gas flow rates (and leaks), perform leak test (engine seal tests), check reeds and perform Link-Synch (which is setting timing) as well. They also adjust the carbs and its idling. After a good "baseline" reset (sort of speaking) from an experienced boat mechanic, then get a good engine book. And, do yearly maintenance tasks / future fixings yourself.
Unknown to some, many engines have a plastic bushing on their throttle rod. It rolls instead of wearing out 2 contact points. If this plastic bushing splits and falls off, it will throw its timing way off. A good boat mechanic will also inspect and replace these items as well. Then, reset its timing.
Hope this helps.
Eyegouger
Thanx for the input. I have a certified mechanic going over it now. Also was told to install water separator.
batman99
Yes. Installing Water / Fuel Separator (and changing its 5 micron filter every spring) is a great idea as well. One of the 1st upgrades I apply to my OB engines.
