1978 140 hp mercury power problems
aps71285
Idk chris i dont think it was a lean condition or overheating. I think i just pushed it too hard
Just so you know, the carb mix screw only affects the motor up to 1200 RPM or so. At that point the main jet (bottom of carb, under the brass plug) controls the mixture. If that jet is clean, the high speed mix should be fine.
cuenta619
Good info.
Thank sr. Everyday I learned more read your post
Exelent.
Faztbullet
. Cyl 1 is down to 90 psi and 3 is at 30.
Trigger went bad....Distributer trigger can do some goofy and unexplainable things when going bad. Learned this years ago at Mercury school
aps71285
Idk how to get a pic uploaded of the spark plug but something definitely came apart inside. Ill keep tyring to up load oic
Check around the entire crankcase. If a bearing or rod failed, you will see the exit wound.....
cuenta619
No Title
what kind of spark you were using
US like this in the pic.
aps71285
No Title
This is what the #1 and #3 spark plugs look like. The stuff on the wnd appears to be aluminium but its stuck on there it doesnt wipe off
aps71285
Chris1956 will parts off of my 140 interchange with an 1150?
Faztbullet
That aluminum throw off from piston dome erosion due to preignition, take a knife and it will pop off plug as a cast disk. Depending on 115 year model a lot of parts will interchange...
cuenta619
you're talking about
the maximum spark advance ??
I can't go out and test the motor by bad weather here in fl.
explains a little more to not make the same error.
aps71285
Pulling it apart today to see what broke. I will post pics asap
aps71285
That is piston 3. It is scored on the side pretty bad, and looks like the top was melting. What caused this? Also that piston is only a 2 ring piston and the rest have 3. Is that normal. Its also the only one stamped .015 on the top.
