running my johnson 2001 150 without the wiring harness
JQ1
I'm in the middle of rewiring my harness to the front console along with most of the wiring. It's taking me some time because I'm trying to clean up the tube where all the wires run though. Anyway....my engine is a 2 stroke. I don't like having the engine sitting without at least turning it over once a week. I have a remote starter that I use when I'm troubleshooting so I don't have to go all the way up to the console to turn it over. Is it ok to start it without the harness that goes to all the control gauges and a then just kill it grounding the black/ yellow wire. I could do that or just advance the timing all the way so it stalls. I just want to make sure I don't harm anything on the powerpack or missing something that has to be looped that the engine electronics checks for.
First of all, I think you are worried for no reason. A motor can sit for weeks w/o issue. Remember they sit over the winter. If it bothers you, pull the spark plugs and pump some fogging oil into the cylinders and carb throats.
If you must start it, I would disconnect the voltage regulator from the stator. I would think the powerpack would be fine, since the only connection to the dashboard is the killer wire. I think (think) the balance of the wiring is OK to leave disconnected. Don't forget the flusher and you can manually choke her to start and stop her.
reiddo1
. Good luck trying to manually choke that engine! I ran mine at idle with no harness with no problems except that to shut down I had to pull spark plug boots until it stalled. I believe it kept running until the 4th wire was pulled. I had the same concern about the voltage regulator too but no problems materialized.
