Will this work???
21270
I have a 94 4.3lx merc with carburetor and full closed cooling system. Would a water crossover work on this set up or do i need the circulation pump to keep the antifreeze moving in the block. I dont know much about these crossovers.<br /> Thanks you.
Haut Medoc
Re: Will this work???
Not sure what a crossover is.....Your engine should not need any modification to operate within acceptable temperature range....Are you having a heat or circulation problem?.....JK
21270
J.kopec, no heat problem what so ever. Just was wondering if it would work so i could get rid of the circulation pump and belt (looks a little cleaner). A crossover is a 1 1/4 stainless pipe that mounts on the front of the engine block where the circulation pump would be mounted. The pipe allows the antifreeze to enter and exit the entire block.
bomar76
A cross over can cause a bunch of problems on Alpha's....and Bravo's too, to a lesser extent.<br />I toyed with the idea of going that route and picking up a few free HP but it's not worth the risk.<br />Since you are closed cooling you HAVE to have the circ pump, so it's not an option for you.
21270
bomar76, is this because without the circulation pump, the antifreeze will just sit and heat up?<br /> Thank You!!
Ayuh,..........<br /><br />Cross-over tubes are used on Raw water cooled Jet-powered boats,.........<br /><br />Not on I/O powered boats,........<br /><br />And,.. Diffinetly Not on Freshwater cooled system............
bomar76
<br /><br />Cross-over tubes are used on Raw water cooled Jet-powered boats,.........<br /><br />Not on I/O powered boats,........<br /> [/QB]
Sorry to burst your bubble there, but crossovers are fairly common on even moderate High Performance I/O boats.
bomar76
Originally posted by jgw:<br /> bomar76, is this because without the circulation pump, the antifreeze will just sit and heat up?<br /> Thank You!!
Yes, you HAVE to have a circ pump to move the antifreeze in your type of system.
