johnson outboard
josh18
So took the boat out yesterday and rode around for about 30 minutes to a hour and cut the motor off Nx did some fishing and when I went to start it up the flywheel was so tight I couldn't budge it
NAT1VE
What ratio did you mix the gas, and have you tried turning the motor since?
josh18
50s model 5 hp johnson and yes have tried would not having oil in the lower unit cause to tighten up
Sunken Ship
How much oil did you put in the gas and how many gallons of gas did you put in there?
hunter200524
Yes if you had no oil in the lower unit it is most likely locked up. Pull off the gearcase then try turning over the motor.
oldboat1
think hunter has it right ^^ (your question implies an issue there....) Can try a combination of operating the gearshift, nudging prop, flywheel by hand (motor off) -- try to free up the gears. If you forgot to add oil, I would first fill it up and see if the mechanism will work for you (shifts in and out of gear -- again, may have to nudge prop or flywheel to shift.) If seems to operate normally, can try motor. Can't hurt to be optimistic.
josh18
Yea I pulled the lower unit off last night and was hardly any oil in it
lindy46
80-90wt marine gear lube. Is the lower unit locked up? Or is it the engine?
josh18
I mean i can move the flywheel some it's just very hard to move I took lower unit off and the long rod was hardly wet at all
josh18
Cause I had just got done running it the other day on the water and stopped for about 20 minutes then tried to crank back up and it was like it was froze up didn't wanna spin
F_R
Could be a busted shock absorber spring. Is it a 5hp w/neutral clutch, or is it a 5.5hp with full gearshift? It helps to know these things.
60sboater
You might have a "double whammy"...good luck. Is this your first outboard?
