Won't start, well kinda...
schuder
I'm still trying to start my 1959 35hp Johnson
It starts and runs a few seconds then quits. It has LOTS of spark. But when I check the plugs they are both bone dry. I can see the clear glass gas filter is full of gas. And the primer bulb is hard. So why is there no gas on the plugs?
lindy46
Yup, carb cleaning/rebuilding is in order. Once this is done, set the low speed needle out 1.5 turns and the high speed needle out 3/4 turn to start.
schuder
Thank you guys. When you are saying rebuild what parts were that consist of
lindy46
Float, float valve and seat, nozzle gasket, carb bowl gasket, packing for the needle valves. Get a carb kit, available here at Iboats 18-7024. That doesn't include the float.
schuder
Opps I meant lindy46. Also I have the same boat that is in your profile picture
Bosunsmate
How do I know if it needs a new float?
if it doesnt float when placed on gas, sounds more like a sticky valve to me, or someone has installed it wrong and its closing the valve far too early
lindy46
Original float would have been cork, and if the original is still in there, it probably needs to be replaced. They lose their coating and get black and flaky and clog up the carb.
schuder
Ok now I know. Thanks. I will be taking the carb apart tomorrow to see what's going on. Thanks again
