1964 Johnson Meteor 90hp question
Mortado
I just got this along with a 1959 Glasspar Avalon. Is this amount of smoke normal? New to old outboards, previous experience only sailing with a tiny kicker motor. Running at the 24-1 ratio specified on the motor itself.
https://youtu.be/okYlHr_7Rwk
F_R
Perfectly normal. Especially since it is running in a bucket. But it is getting pretty warm (judging by the amount of water being discharged). That could be because it is in a bucket, or it could be because the thermostat is stuck open. Just don't monkey around and overheat it.
Mortado
In 1964 OMC went to a 50:1 mix on those motors.
Very interesting as the plate on the motor itself calls for 1 quart of oil to 6 gallons of gas. Do you know if that was retroactively applied after some of the 1964 model year motors already were produced and sold?
Please note that the model number from the plate is V4ML-10S. All the info I can find on the web tells me it is indeed a 1964 motor.
Mortado
Is this change to 50:1 documented anywhere? I find it kind of odd as the motor itself has a plate which states 1 quart of oil to 6 gallons of gas.
F_R
Actually, in 1964, 50:1 was only specified if you used Johnson or Evinrude TCW oil. Of course, today's TC-W3 oil is totally different stuff. I'll leave it to you to decide what you want to do. Personally, I would not hesitate one minute to run it on 50:1. That testimony plus $1.95 + tax will get you a cup of coffee at the finest gas station in town.
G
Guest
Guest
I had a 1963 Johnson 40hp on a 16' Lyman when I was in high school back in the 1970's. it too required a 24:1 mix.
I was using 1 qt of 30W oil to six gallons until the local Evinrude dealer said just use 50:1. I never had a problem at all, the engine smoked a whole lot less and ran with absolutely no issues.
You'll be fine running today's TCW-3 oils at 50:1
Mortado
Thank you for the replies! Would using a good TCW-3 synthetic would decrease the smoke even further?
