OFF THE CLOCK
Thread starter- Joined
- Jun 6, 2015
- 21
Ok this is the issue. Engine was running 4400 rpm on plain lost power (cut in out in out). Never died, put throttle back to idle stop position. Engine idled with slight shake. WOT never regained speed or thrust. Removed all fuel checked fuel water none present. Removed carburetors checked jets both no issues compression even 125psi x4. Started engine in a tank will idle won't start right up but it will and will idle.
While on trailer @ ramp WOT you could hear the engine cutting in and out (one side or another coming alive) but still not full power. Running boat down the ICW shut key off engine would still run (less power) turn key on (1/2) power back to original issue. So it is safe to say there is an issue in with the key switch wiring. Now that being said I guess the key switch being in the off position it was in fact putting a charge to something while sitting in the driveway waiting for the next outing. So what do you think was cooking while the battery was hooked up? coil coils under flywheel, Now I also replaced the power packs and all coils (have 3 sets of them) spare parts. Checked all wires in and around harness for breaks and corrosion. Went completely through inspected all points everything appears to be intact. Will idle slow to plain no power. Like I said this happen while under load @ 4400 rps on plain. Engine ran fine up to this moment still running somewhat above idle to plowing will plow WOT nobody's home so to speak. Have manual, fully tooled will go through the checks of resistance's etc troubleshoot parts electrical. Looking for the reason and what you might test first thanks.
