1984 Johnson v4 140 start questions
Kiltedcomic
Hey all,
I just purchased a 1985 Wellcraft 18 Fisherman with a Johnson v4 140hp. I had my local Johnson repair guy go over it and he replaced a few things.
My questions are:
1). When starting, how long do I need to push the key in (choke) prior to engaging the starter?
2). Will the choke automatically close once the engine is warm or will I need to restart once it's warmed up?
3). How long is the usual warm up time?
Thanks all.
You do not push the key in before cranking !!----You push the key in and hold it in while cranking it over.-----????--Automatic chokes would normally OPEN after warmup---BUT--there is no " automatic choke " on this motor.------If thermostats are installed the motor will warmup in less than a minute.
ondarvr
Hey all,
My questions are:
Thanks all.
1. How long and when to push the key in totally depends on the exact motor and how it likes to start.
It will start whether you push the key in before or as you turn the key, some motors like to start quicker when you push the key in for a couple of seconds prior to turning the key though. When you squeeze the primer bulb in the fuel line it will slightly pressurize the system, when you push the key in this allows some fuel to flow into the intake prior to turning the key, which can help it start sooner. If you push it in as you turn the key it may take a revolution or two before fuel inters the intake and it starts. I always push it prior to turning the key.
2. There is no choke, pushing in the key activates the enrichment system that replaces a normal choke. When you stop pushing in on the key it stops working, so you don't need to anything. You may need to push it in a couple of times when it's cold to keep it running until it warms up.
3. Just like an old school carbed car, the time it takes to warm up depends on many factors, ambient temp, water temp, RPM's, load, etc. It should only take a few minutes though.
ondarvr
I hate posting from my phone and not being able to edit what I just posted.
Kiltedcomic
I am having the hardest time keeping this thing running. I get it to start but it only stays running for 10-30 seconds then it dies out. I've checked the plugs, bulb is firm, trying to advance the throttle while running only causes it to die off quicker.
Post the results of a compression test.-------That is how the trouble shooting starts !
