initially wanted to note that the t.stat on that motor is a little hard to get at, and suggest leaving it alone if temp seems OK. But in your discussion, you indicate you can hold your hand on the head somewhere for a minute or so while at or close to WOT. That says to me it?s running cold, and the t.stat might be stuck.
To remove the thermostat (down at the bottom of the bottom cylinder), remove the cylinder head. On your workbench, remove the oddly shaped t.stat cover on the cylinder head for access to the thermostat. Check a parts blowup before beginning to see the configuration(s). The t.stat is held in place by a spring, so when removing the cover be aware there is some spring action pushing the cover out. To get the lower head cover bolts out (and in), you have partially remove/insert to clear the pan. It?s a tight fit.
You can check the thermostat, but I recommend just replacing it with a new one ? t.stat and its rubber washer. As I recall, the flange of the thermostat sits on top of the rubber washer on your model (not the type that goes around the flange).
You need a head gasket and a t.stat cover gasket. You might find with a new head gasket that the issue with the lower cylinder might be taken care of, but in any case it sounds like the engine temp might be better. You should be able to hold a couple of fingers on the top of the head (not around the cylinders where it?s hotter) for a few seconds. About 140 degrees or so. It wouldn?t hurt to get an infrared temp. gun if you want to get a check on surface temps.
Beyond that, do not run with anything leaner than 50:1. Test operation in a barrel on in the lake (low rpms if in a barrel). Use of muffs can disguise cooling issues.
