I recently bought a 20hp Johnson and when I can get it to run, it idles very fast and the choke plate "bounces" with great speed(opens and closes). It helps to keep it running if I hold the plate with my finger to limit the "bouncing". I came across a thread on here where "racerone" was talking about reed valve problems. He said to remove top plug and see if motor will start and keep running and then to put that one back in and remove the bottom plug and see if it will start and run. I removed the top plug and it would not start. I put that one back in and removed the bottom plug and it started immediately and stayed running. To be sure I did not have a bad plug, I put the bottom plug(the one that would NOT run) in the top cylinder and tried to start it. It did not run. So I figured I had a bad plug. I went and picked up two new plugs, gapped them and installed them. I started the motor and right away I could tell it didn't fix my problem. I tried to adjust the idle speed knob on the front of the motor to no avail. It had absolutely no effect on idle. After about 20 seconds of run time, I killed it and pulled the plugs. Below is a picture of the plugs.
racerone, if you see this would you mind telling me what to do next in determining a reed valve problem.
Left one is the top cylinder plug and the right one is the bottom cylinder plug.
After pulling the plugs, I called it a night.
Are these plugs and what I have observed symptoms of a reed valve problem? Or something else?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
