73' 6HP Evinrude Will Not Throttle Up
jignscoff
I have a 6hp Evinrude on my 14' Jon LT (the lighter version).
So far is has: New coils, new plugs, carb kit, new fuel lines, new impeller, new gear oil. All completed by a professional.
The motor runs fine and revs up in neutral, also in reverse. But in forward it never seems to completely reach full RPM. Around half is my guess. It does not bog, or sputter. It just doesn't rev up.
This guy has a similar setup but with a much heavier boat and i don't reach this RPM, not even close. https://www.youtube.com/watch?v=t3bgw8tiB-w
Any ideas?
Does spark jump a gap of 1/4" or more, yes or no ?----Does primer bulb go hard when you operate it ?----Have you done a compression test ?-----Quite common for head gasket to blow between cylinders.
jignscoff
I did not gap the plugs. I will install a hotter plug and gap to 1/4" tonight. The ones I have get pretty dirty.
Primer Bulb is hard.
Will test compression tonight.
????----Nobody said anything about gapping plugs at 1/4"---We are asking you to TEST THE IGNITION SYSTEM.---So does the spark jump a gap of 1/4" or more, yes or no ?
Tim Frank
Installing a hotter plug is unlikely to solve anything and may damage the motor.
Gapping a plug to 1/4" will probably not damage anything....except the plug.... :)
You need a systematic approach to troubleshooting, one step at a time. If you go all over the map, so will your results.
My best advice....read everything Racerone posts and follow his suggestions and answer his questions.
He's not the most patient member in here, just one of the most knowledgeable. :)
Really useful info that is missing....has this motor ever run as well as you are hoping? ....how are you determining RPM?.... a 14 ft. Jon is still a good push for a 6 hp. There is no excess power and trim and balance will be critical.
Crosbyman
touch the plugs after a few minutes to see if both are hot... my recent experience on a 9.5 came up as bad coil on the lower cyl. (original & cracked but its an old engine)
you could scan the block with an infrared temp meter
you must ensure that both plugs are firing adequately after you know the compression numbers are ok .
better pull the flywheel and service the electricals
????----He says a pro has already installed new coils and serviced it !!!!
Crosbyman
he said his repair shop replaced the coils ...... "new" is not the same as good...and working ok
.no disrespect to his shop but I would reservice the electricals and confirm all is ok ignition wise incl points condenser etc...
in any event there is no choice but check everything from the the ground up
just mho.
geedo2
Hey, this is way too simple. Get me some numbers off the prop and if its the right prop, then make sure you trim the motor in the right hole for your boat and load. I am only thinking that the little 6 has already been properly tuned up.
jignscoff
racerone compression is 70-80lbs in both cylinders. Have not tested spark - yet.
Tim Frank Quite an audible difference in RPM between what I see in that video and what I hear when I was last in the boat on the water (Sunday).
geedo2 how would I properly trim the motor? like when would I know the pin is in the right hole?
flyingscott
Okay so your motor seems healthy kind of bothers me they didn't change points and condensers as they were already under the flywheel to replace the coils. Here is a simple test start it up in a barrel of water or similiar. Get a leather glove start it up and pull each spark plug wire off one at a time it should run on one cyl if it dies one cyl has no spark.
Vic.S
70 to 80 psi is not bad but did you follow the procedure recommended on the Engine FAQs board or in the Top Secret File? Do you even know how accurate your gauge is?
The engine sounds to be running smoothly with no missing or hesitation when throttling up. If it also starts easily I would not be worried about the coils, condensers or points although if the points gap is wrong it would affect the ignition timing and perhaps the overall performance. To check the gap is the only reason I would consider going under the flywheel again.
Is the prop correct/original. If it had been replaced with one with a different pitch it would affect the top rpm.
Have you checked that the carb throttle plate opens fully and that it is properly synchronized with the magneto.
At the end of the day is your boat speed what you would expect. There is no point in increasing the engine rpm if it does not increase the boat speed.
geedo2
When you power up the bow will rise, if it stays up then you have to move the trim pin one hole closer to the transom. The bow should then rise as you power then begin to drop and level off, that puts the boat "on step" and provides best speed. If the motor and load is correct, I find that the first or second hole closest to the transom is best. If you are loading the boat "bow heavy" you have to use the motors power to lift up the bow and you are wasting energy, no matter where you put the trim adjustment. Once the boat is on step then often you set the trim to raise the bow slightly for optimum speed but only just enough lift before the bow will start to bounce up and down "porpoise". This can only be done with "power trim" because you can't stop the boat to change trim with a manual unit like the little outboards use. Also note that there is a large variety of prop options for this little motor and I'd like to know what your running. I like the props marked 5 1/2 for most applications on the 5.5 and 6 horsepowers. These are 2 bladed props. Note: I have changed coils but not points on some jobs because the points look good (no pitting) and test out properly when using my multi meter. Points often fail because of oil and crud that escape from the upper crank seal. Sometimes techs will set the coils too close to the flywheel causing abrasion with the magnets and creating fine metallic dust........it all cuts short the life of your points. As for the condensers I can test those too. I charge them with a transformer, then scan the body for leaks, then check output after a few seconds by arcing the wire back to the case. You can then study each condenser and its performance. Some new condensers are not as good as OEM stuff. Contrary to belief, condensers rarely fail but yet are included in kits to ensure a successful tune up as they are inexpensive.
pro-crastinator
COuple of thoughts.
1. Have we seen a video of the actual 6hp motor in question? - or was the video posted as an example of what the goal is?
2. Has the carb been removed ? (re-installation process is easy to make an error that can yield the described symptoms)
3. The "problem" is either fuel or ignition. Ignition is an easy, sometimes straightforward, solution that "solves" well via email.
4. Fuel quality and fuel delivery is also a high probability that should not be ignored.
5. good luck.
jignscoff
racerone Top cylinder wire will spark across 1/2". Bottom Cylinder wire will not spark across 1/4". Dialed it back to 1/8" and it sparked.
Vic.S do not know how accurate the gauge is. It was borrowed from a friend. Brand new out of package. Prop is original, aluminum (sometimes they came plastic). Have not checked carb plates w/ magneto.
pro-crastinator Not the actual motor. Same model, similar boat (14 ft jon). Carb was removed and cleaned by a service tech. See above for ignition information. The gas is new 50/1. The tank is original but brand new fuel line & primer bulb.
AlTn
try cutting off 1/2" of the plug wire on the plug end, reinserting the wire terminal into the boot then check your spark again for that lower cylinder....the terminal end of the spark plug wire pulls out of the boot..a little wd will help it slide out...you'd think the "tech" who replaced the coil would have done this on the coil end of the spark plug wire as well, but who knows...you may well have to pull the flywheel if the spark is still weak after working on the spark plug end of the wire...
