5.5 Evinrude fisherman (1963-64) Challenge
Evintude
My evinrude 5.5 fisherman (1964) was not wanting to idle, will run at medium and high rpms. Discovered the compression was bad. So bought a new powerhead with good compression (80-80), clean and rebuilt the carb to spec, did an ignition tune-up, rebuilt the lower unit and water pump (for good measure), fresh gas, new plugs, and now the thing will only run low rpm's at WOT. It won't idle, it wont even run unless you're at full throttle. It starts fine first or second pull in the start throttle position then you go to rev it and It sounds like its bogging. I just cant get it to rev up, and as soon as you let off the throttle it dies. It will only ever run for a minute or less. The throttle plate appears to opening up fully on the carb. I have the jets both out at the 1-1/2 turns out.
Since it didn't do this before the new powerhead, and I am only able to get it to start and idle for a mintue before it dies. I decided to rebuild the old power head (now has good compression) and give that a shot. SAME THING, Could the timing be that far off? The fuel pump blasts fuel out if you crank it with the out line off, the bulb stays relatively firm, everything new essentially. What the heck could it be? The plugs come out wet with clean fuel, not sooty at all.
Is there a common problem with syncing the timing and the carb when you do a complete over haul? I'm lost, I'm thinking of buying a new fuel pump because I just don't know what it could be.
Th
THANKS SO MUCH GUYS
Tim Frank
First thing I'd verify is the fuel tank and lines to the motor for air leaks, make sure the bulb is oriented correctly....arrow pointing at motor, and if tank has a vent, that it is open.
Evintude
Thanks Tim, everything there looks good. I also put all new fuel lines. Is it possible that the tank line connector is bad? It doesn't leak or anything.
gm280
Evintude, when you rebuilt the carb, did you disassembly everything and use carb spray or did you wash out the fuel bowl and reinstall? I think you have a carb issue myself. What you honestly have to do is disassembly everything on the carb, That means every screw, jet, orifices, and what ever it takes to get into the little tiny holes and slots in those carbs. Use carb spray and compressed air along with fine copper wire to verify every hole is cleared and clean. Spray carb cleaner through every hole as well. Then install a carb kit in it with new gaskets, needle and seat and packing material and set the float to the proper level after verifying it is not bad and start over tuning it to the engine. JMHO!
F_R
High speed needle at 1-1/2 turns out is way too rich. It should be chugging along and going nowhere at such a rich setting. Set it at 3/4 turn open, then while running WOT on a boat on the lake, readjust it for smooth running and top speed. Usually you will have to turn it in a tad from the 3/4 preset. But if you screw it in, and it conks out, too lean and you need to back it off a bit.
Tim Frank
That fuel line stuff was "free"....no cost and always a good one to rule out.
Verify that the ignition system is OK by using a proper spark tester and look for at least a 1/4" gap-jump with an traditional magneto system. (just because you have all new ignition components does not mean that you haven't made a mistake or two in reassembly.
I am not disagreeing with either Guru who is pointing you at the carbs, but the spark test is so quick and easy (well worth the LT $10- cost of a pre-made tester or the few minutes to make your own)
If you get that test done and it is successful, move on to carb/fuel system.
Tim Frank
The tank fitting typically does not leak "visibly" as it is the suction end, but a suction leak can certainly leave you "dead in the water".Make sure that your bulb is oriented OK....the OEM manual shows how to test fuel flow to the carb "quantitatively" with a gauge which will narrow down problems to either air leaks or fuel pump weakness/failure.
Evintude
Guys I can't tell you how much I appreciate the suggestions. I turned the high speed screw in all the way and tried it then, a half, then three quarters, all to no avail. I'm guessing I should buy another carb rebuild kit and really go town with it, soak overnight and all. Does anybody think I can safely rule out a fuel pump. Everybody I know has said its a carb issue, I just felt like it looked so clean and I rebuilt it that that would do the job.
Tim Frank
If you can, borrow a friend's tank and hose who is having no problem with their rig. If you are really lucky, your motor will run fine, and you've found your problem.
Otherwise, you have at least eliminated one source of trouble, and at zero cost and little time and dis-assembly.
OptsyEagle
Are you sure both cylinders are firing. Usually when you are not getting many RPMs at WOT it is because the motor is running on only one cylinder. To test this, start it up and let it warm up. Bring it to a fast idle and with a pair of insulated pliers pull one spark plug boot at a time. The motor should be able to run on only one cylinder, albeit at a much reduced power, so if the motor dies when a plug boot is pulled you know the other cylinder was not working or was very weak.
Also, I assume you sync'd the carb to the throttle cam but if not you want the line on the throttle cam to be in the center of the carb's roller just as the throttle butterfly starts to open. Put an alligator clip on the part of the butterfly that is on the starboard side of the carb so you can easily see when the butterfly JUST starts to open. Make sure your choke is not engaged when you do this synchronization.
If spark can not jump a gap of 1/4" or more you essentially have a " no spark condition "---Laying the plugs on the block is not a good test at all.
