KrazyAlaska
Thread starter- Joined
- Jul 5, 2015
- 10
So I removed the starter on my 1991 120 force. Lubed the bendix threads reinstalled it. Hit the key and it turned over. Great! Went to hit it again to confirm a job well done and it just clicked. One click Each time I turn the key. Removed starter fired it from battery and it worked fine. Noticed upon removal of hot wire I put the connector right on the housing against the fabric seperator. So I put the nut back on that should have there originaly. Reinstalled it. Checked battery voltage. 12.7. Checked it again at solenoid. 12.7 checked the other side the goes to starter. Less than 6v when I turn key over. Is this correct voltage ?Any ideas?
