dufrain
Thread starter- Joined
- Apr 30, 2012
- 13
Im trying to find a pesky leak. Here is my oil before and after i ran it for a few hours . It was new oil yesterday. I had pulled the outdrive off it the day before to try to find the leak.I pulled the prop and there was no water in the driveshaft boot . I drained it then put a new small o ring between the 2 units and it held 20 psi for around 30 minutes. I pulled a vacuum with a mighty vac it held also. I sprayed soapy water on the seals couldn't find a thing. While i had separated i pressure tested the lower ,it held fine, The upper I tried to test separate air would leak at the vertical driveshaft seals without the shaft in place. Should air leak from there with no shaft in place or to test separated does this area need a plug installed there. .
