Gotta Pump The Bulb
Macgyver5421
Hi.. I have hey 03 Johnson 150 . It starts up fine drives fine but soon as I give it gas it hesitates . I pump the ball then it takes off then 10 seconds it slows back down then the pump the ball then it takes off again . I don't know if my pump is going out or I have a clog somewhere?
GA_Boater
Moved this post to it's own thread. Please look at the Help Tips on top of the page and please do not post in inactive threads. Thanks.
Vic.S
Your fuel pump may be defective or there may be a leak causing air to be sucked in somewhere
Places to check are the fuel line from primer bulb to main strainer, vapor separator cover, vapor pump and various fuel line to fittings.
gm280
"welcome: MacGyver to iboats...
If you have any leaks between the primer bulb and the engine or even the carb, there would be fuel leaking out when you squeeze the primer bulb to primer the engine. So I'm leaning towards a bad fuel pump. If you want to verify the pump, remove the fuel line from the carb and crank the engine over. If the fuel pump is working properly, you will see a flow of fuel out of the fuel line. If it isn't flowing out well, rebuild or replace the fuel pump...
GA_Boater
What gm280 said. The fuel will spurt as the motor spins, so don't look for a flow like water out of a faucet. Try to catch the flow in something and watch the eyes.
Macgyver5421
When I got home from work to pull the cover off the motor Then realize two of the gas line leading to the carburetor were never clamp know you have to do is move the hose and wate then realize two of the gas line leading to the carburetor were never clamp know you have to do is move the hose and The funeral will squirt out . Checked all the hoses and put cramps Checked all the hoses and put cramps and zip ties and all the houses . I pump up the ball and fuel came out. Took it to the river and took it for a test drive and it's doing the same thing. While at the river I pool one of the hoses that leads to the carburetor and stuck it to a bottle and watch the fuel run through it it wasn't a steady stream it was more like powdering. I'm sorry I think it was the fuel pump. Any ideas?
NicoPags
Try this now
Macgyver5421
Took the fuel pump apart today and sure enough there's a rip on diaphragm. Going to order the rebuild kit and hopefully that would fix the problem thank you guys
