Question about distributor
tommybrown1094
Hi I have been doing some reading on the sticky's on this forum and I'm thinking I did not set my timing right. I had pulled intake (cracked) reinstalled everything. On the distributor i just dropped it in lined up with #1, fired the engine set it to 0 at an idle.Runs fine at idle, have not had time to make it to the water. Does my engine use the EST distributor and do I need to go back and follow the instructions for setting the EST distributor timing. I tried googling it but only found how to set the timing. Thanks in advance
1997 4.3 GS Volvo Penta
Tommy
bruceb58
Yes, you do have an EST distributor. How you set timing depends on if you have a carb or fuel injection. You need to put it into base timing mode. With a carb, you need the timing shunt. With FI you need to short two pins in the datallink connector.
tommybrown1094
Thank you for the reply. I have a 2 barrel carb. (non EFI) I was doing more reading last night, I need to buy the Volvo adapter plug to set the timing. Thanks for all the help!!!!
