Evinrude 1995 225: brand new stator is getting burned
SandBarBoat
I have recently gotten a supposed Evinrude 225 1995 "Frankenrude", that I made the mistake of buying in craiglist, running after long months of dealing with different mechanics and lots of bills. No one seamed to be able to figure out why the engine was stalling under load. Everything was checked: compression, timing, reed valves, carburetors, calibration pockets, re circulation system, fuel lines and pump, electronics.....I end up having to take the motor to a mechanics school which were the only ones willing to take the time to figure out was going on without starting swapping parts right away. After a long time finding different issues and many parts replaced and rebuilt I got the engine back but 80% of the times i have to press the choke to prevent it from stalling when i throttle it up from 900 to 1500 rpm. Once above 1500rpm the engine seem to run and speed up good. I have been using it for around a month with the help of the choke while I wait for the new school year to start in August because is when they are going to finish fixing the engine. After all the different mechanics that tryed to fix the engine, I end up getting a new power pack, CDI voltage regulator, CDI stator, timer base, VRO and carburators rebuilt kits, and two reed valves blocks replaced. Last time I used the boat i went to a key nearby. Once there I open the engine case and I noticed a burned electronic smell. I trace the smell down to a stator coil that is overheating. This coil seams to be different from the rest of coils and it has two orange cables that goes into the power pack. Next day I cleaned the battery connections really good because they looked a little bit dirty and rusty and went for another spin to check if the problem went away but same thing, after open the engine cover I could smell again something similar to burned cables and a white cover on the stator coil that was overheating is turning dark brown. The flywheel was also hot. The boat runs but I'm scared of breaking it and i"m also very skeptical of taking it to a mechanic in the area after my previous experience. I really appreciate any ideas or suggestions that could help me troubleshoot and fix the problem myself before having to take it to another mechanic or wait without using the boat until August for the school to open again.
Thank you all very much for your help,
Happy boating!!
daselbee
Because I don't know what the EFF I am talking about. Ask anyone here.
Or, maybe just maybe, the charging current the stator is putting out at a long long duration, trying to charge a bad sulfated battery...maybe, just maybe, it is burning the stator up.
Oh, but wait. That is not the orange coil. That's why never mind.
EFF this place. Good luck. (I am drunk too.)
