sheboyganjohn
Thread starter- Joined
- Aug 2, 2005
- 753
I have been lurking for a long time and this is my first post. I have a 1973 Starcraft with a 888 outdrive 302 ford with 400 hrs on it. Just picked it up this year. It spent its whole life out of the water in a boat house. In my grand ignerance I blew the lower unit water pump before my first trip out (had it in a drum of water over the intake but below the water pump) and found out I had blown it a couple miles out on the lake after I had managed to melt the shift cable to the exhaust. Had the lower unit repaired but had the guy leave the engine for me. Everything ran fairly well the next trip out but it ran worse the hotter it got. Had a hard time getting it started when it was hot and would die when I went back to idle to shift. When it would cool down completely it ran fine. Well today I was working on the boat (changing out thermostat and cleaning up the front of the engine) when I decided to check the oil again. Well low and behold it is nice and milky. I am guessing it is a bad head gasket. I did some initial searching and found that the marine intake and head set is well over $100. The closest this boat will get to salt water is if someone drops a margarita overboard so I am assuming the auto version of the gaskets should work fine. The only problem is that from what I have read, this engine is a 302 with 351 heads. What do I use for gaskets, 351's or 302's, and what auto version matches up? Any help would be appreciated. By the way, I checked everything real well when I bought the boat and took it out for a while right before I handed over the check and everything ran well both wide open and at idle, all fluid were good etc. so this is all self inflicted this summer.
