Hi all, I'm new here and new in boating,so to hit me hard if I ask something stupid.
Recently I've got trailer, boat and motor in "one bad" all in good working order except for motor. Motor is old 1962 JWL-17 It started from third or fourth pull and but wasnt very stable. To improve startup I tuned gaps in ignition system, changed fuel with 24:1 mix, tuned high and low speed levers according to manual (high speed 3/4 turn and low speed 2 turns) tried to start it with NO RESULT! Chock didnt help, motor wouldnt start at all! I opened carburetor without removing it and saw that it was full of fuel after letting that fuel out and closing, motor started but I had to move high speed lever to max right position (close it more) to keep motor running. Motor was also smoking a lot and I thought that something wrong with mix. I add more gas to mix making it approximately 30:1, motor starts now and works, but I cannot call this work stable. Short time after starting motor shakes and going to higher speed then to lower then to higher again and so on, and after doing that a few times it finally raises rpms and working steady. Well, it runs well on higher rpms (not going too high though but maybe it suppose to be like that) but it dies when I try to move throttle lower than start position. It also dies when I pull the chock. It also feels like it consumes too much petrol.
Can anyone help me? I wouldnt like to completely dismantle carburetor because I'm not motor specialist at all, are there any ways to avoid it?
While on lower rpms tuning with low speed lever doesnt do much (if does anything at all)
