Pull rope keeps letting go looking for replacement
Erics512
The pull cord on my 1954 seahorse 5.5 hp. keeps letting go. The original rope with metal twine and the hook , is no longer useable. Can I get a replacement rope like the original one or what's my options. I used a pull rope from the hardware store and tied a knot in the end of it but it keeps pulling through.
Tim Frank
Not sure what you are asking. Can you explain in a bit more detail?
Erics512
Looking to see if there is a replacement rope available...the one with the metal in the middle, with the hook at the end. And if it's not available what is the best solution.? Every time I tie a knot in the end of the rope, it pulls out of the motor.
175se
Had that problem maybe 5/6 years ago, it was available then don't know about now, youre right nothing else seems to last.
Chinewalker
If you're pulling the rope out with that much regularity, you're either using the wrong rope, the wrong length of rope, or tying the wrong knot. Hardware store rope may not hold up. Try a small engine shop.
Erics512
Anyone have a part number for the original? And I was using the lawn mower handle repair kits. My knot tying skills aren't that good. " can't tie a knot tie a lot"
boobie
OMC dlrs used to have a nylon rope with a metal end the same as the original. They held up pretty good. Give them a try or use the genuine OMC starter rope with a good knot in it.
