greentahoe
Thread starter- Joined
- Jul 30, 2005
- 55
I have a 1984 OMC stringer 3.8, 185 hp 4bbl quadrajet. Last time out fishing it wouldn't idle on the way in. Back at home it started but skipped a lot. It was time for a tuenup anyway so I changed the points, condenser, rotor, dist. cap, plugs, plug wires, coil, and fixed a frayed wire to the + side of the coil. Now it starts well but it breaks up at high rpm's. I've checked with the stethescope for a vacuum leak but haven't been able to detect one. I haven't changed the fuel filter yet, but that's on my todo list. When I took out the plugs there was no water on them. There is some rust around the points mounting plate inside the distributor, and I haven't taken it out so I don't know what the advance springs look like underneath. I noticed when setting the points that there is a little side play on the distributor shaft, but since the engine was running very well before it began it's skipping problem I doubt that is the cause of the problem.<br />Could there be a problem with the mechanical advance mechanism causing this? <br />I also now have the tach jumping around whereas it has always been very steady.<br />Thanks for any help.
