Hi all. Long time reader first time poster so forgive me if I sound too much of a newbie. I inherited an older boat with a '96 Evinrude 25 hp tiller. I repaired a couple small simple things then put the muffs to it. Started 1st pull. I saw no water coming from the water discharge (pee) hole. I panicked and immediately shut it down. My question is; should the water start coming out immediately?
Your answer will all depend on how long the motor sat in my opinion. Anything sitting for a couple years deserves a new impeller from the start along with a gear lube swap and gear case pressure test to make sure she will take care of you once you get out in the water.
But to answer your question.. When you say "Immediately" shut it down - how long is that exactly.. Seconds? If this is the case then the water may not have had a chance to make it to the tell-tale (pee hole). You may want to shoot a quick shot of compressed air up the tell-tale to make sure there aren't any spider webs or dirt dobbers that may have called that spot home. Some may say not to blow air into it, but i've done it a thousand times and it doesn't hurt anything if you leave it around 30psi.
If your water pump is shot, and not pumping water through the engine then there isn't much harm you can do to it by letting it run for a few extra seconds. The bad stuff happens when you run the engine for a few minutes while no water is pumping, or no water hooked up to the pickup. Put the muffs back on it and let it run for 10-25 seconds. Give it a quick rev in neutral to see if that gets the water flowing. If it is weak, or nothing happens it looks like an impeller job is in your future.
Good luck!
