I have a 1990 Johnson gt150 on the back of my 1990 stratos 275dc bass boat. Engine starts idles and runs well but seems to be lacking top end power. I've noticed that it no longer reaches 5600 rpm like it did last year, maxes out at 5200. I have cleaned all carbs and replaced gaskets, replaced throttle roller, sync'd the linkages, new plugs and wires, new rectifier, checked stator output and resistance, check all 6 igniton coils. I tried to check timing with boat in water strapped to trailer but engine wont spin up past 3000 rpm in gear, doesn't bog or sputter seems to just not have the power. Compression is 105,105,95 on starboard side, port is 99,99,94. Prop size is 14.5x22 boat has dual tanks and runs the same on either tank.
