How do I figure the year on a 3.0 mercruiser
Z Zhulkk Seaman Apprentice Thread starter Joined Aug 7, 2014 Messages 43 May 29, 2015 #1 How do I figure the year on a 3.0 mercruiser
thumpar Admiral Joined Jun 21, 2007 Messages 6,138 May 29, 2015 #2 Post a serial number. There are a few people here that can look them up.
Z Zhulkk Seaman Apprentice Thread starter Joined Aug 7, 2014 Messages 43 Jun 4, 2015 #3 What one would it be? Attachments image.jpg 107.2 KB · Views: 0
dozerII Admiral Joined Oct 25, 2009 Messages 6,527 Jun 4, 2015 #4 It should be on a tag above the starter on the block just below the head where the flywheel cover bolts on.
Z Zhulkk Seaman Apprentice Thread starter Joined Aug 7, 2014 Messages 43 Jun 4, 2015 #5 Okay found it! 816978C and below it is 22241
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,458 Jun 4, 2015 #6 Zhulkk said: Okay found it! 816978C and below it is 22241 Click to expand... Hi there, that doesn't quite look like a mercruiser serial number. Typically the number may start with a C816978 or a 0C816978 but not end with one. As an example, If I change the number you posted around a little (0C816978) it comes up as an 1989 Alpha stern drive. Have a look at the following link for a visual of where the engine serial number should be located. http://forums.iboats.com/forum/engi...n-drive-and-engine-serial-numbers#post6661412
