J200TXEUA 1997 Johnson 200 hp
firefighter4x4
I have been trying to remove my power trim unit and everything was going fairly smooth until it was time to remove the bottom pin. I am wondering if there is a set screw holding this pin as I can see a small hole in the bottom center of the housing but it doesn't look like a screw or anything. I have lubricated many times over and used a large punch and small sledge hammer and this pin isn't budging. Any help....suggestions...input? Help?!?
boobie
A lot of heat, a brass drift (so you don't mushroom the head of the pin) and a BFH. May have to use acy/oxy torch.
firefighter4x4
I was told the white metal of the motor mount which the pin goes through shouldn't be heated
boobie
I live in FL and have heated many of those brackets to get that pin out. Good old salt water. :mad:
Transom brackets are usually forged aluminum. That makes them pretty strong.
That motor should have "keepers" on each side of the trim pin. Make sure you remove them, before hammering/heating.
firefighter4x4
The snap rings on ends of pin are removed, but there is a hole in the bottom of casing where it look as if there was either a grease fitting or possible set screw....in my research I've found where it says this unit should not have a set screw....another attempt to remove pin tomorrow WITH heat as I have a new unit enroute!
firefighter4x4
Boobie...this boat actually came from Florida and was sitting in a slip for a long period of time...hence the corrosion and pin being stuck!
daselbee
You might have to remove the motor from the boat. The large amount of heat required might burn the hull.
Oxy-acetylene torch is required, along with a large drift and a BFH.
