kat-a-tonik
Thread starter- Joined
- Jul 27, 2013
- 123
Thoughts and opinions, does anyone use it in outboards and would it help an antique outboard
It will help you lose weight!
I would never use SeaFoam with an engine that has O2 sensors. I know they claim it won't hurt them but since SeaFoam is half oil, not sure why you would do that on purpose.I used it in the fuel tank of my 2007 Toyota Camry with 95,000 miles on it.
Fired it up and within a minute the miss was gone and the idle went back to normal.
How quickly the motor came around makes me question if there wasn't something else going on there but all he did was pour in some seafoam...
Then there is no reason to put snake oil in it.Thanks for the info, i'm not having problems with motor,
Thanks for the info, i'm not having problems with motor, its just an old motor that hasn't run much in a few years, I bought it a couple of years ago for $65 and have just gotten around to fiddling with it this year, I rebuilt the carb. and changed the ignition plate and all its components from another motor that I knew ran, took it out on the river once and it ran great, ( made my little 14 foot deep V stand up on its end lol, right now im working on replacing all the seals in the gear unit, I was just wondering if burning some seafoam through it might be a good idea.
Again... Pouring it through the carb would loosen carbon.....
Free up stuck valves..... Improve ring seal.....
Those alone can make a big difference IF those problems exist.
If a person were to do that, how much would one use? I'm thinking about dumping some down the carb of my street rod.....
