fuel delivery issues with '63 28hp rude. 28303a
DoubleDan
Need some help with fuel delivery on my 28hp. I have a known good tank, hose and primer bulb. This year has the diaphragm fuel pump, ive replaced the diaphragm and made sure valves and passages are clean and functioning. The pump works best the first few strokes of startup but then but then petters down and will not support carb while idling or any higher rpms. Help is greatly appreciated. Any ideas on next step to diagnosis
F_R
Make sure there are no leaks anywhere between the fuel pump and the gas tank. Even small leaks will admit air bubbles that kill the fuel pump's efficiency.
DoubleDan
Yes it will run if i keep pumping it. I checked the ball valves on the primer bulb and the seemed to be working correctly.
jasper60103
I have the OMC service manual for this motor. Shoot me a PM with your email if you want a copy.
boobie
If it runs okay it sounds like a bad fuel pump or the cylinder is bad that the pump picks up it's pulse from.
DoubleDan
Thanks jasper but i have the manuel. Will compression test show if the cylinder is bad? I put my finger over the hose that comes off the cylinder for the pulse and seems liks good pressure but i dont know how much is needed to function the springs and diaphram in the fuel pump
F_R
If it is running on both cylinders, it has enough crankcase compression to operate the pump.
F_R
Nothing like a simple fuel pressure test T'd in between the pump and carburetor. Fuel pump pressure testers don't cost much. (not talking about the high pressure ones for fuel injection systems)
