Prop stuck in the mud
Bob the book guy
I ran aground in soft mud. Since then, when starting the engine, the "check engine" light comes on with the audio warning sound. What needs to be done? Did I suck mud into the water intake?
steelespike
Welcome, we need the year brand and hp. When does the light come on,as soon as you turn the key?
Did you run into the mud at speed?
iggyw1
Ensign
First thing to check out is the water pick up screen. Take a look and see if the screen is plugged with mud.
emdsapmgr
You may also want to pull the thermostat out and see if there is any debris affecting it's function.
