They (BRP) take the position that the EMM is a part of the emissions system. The feds do not allow modifications to vehicle emissions systems.
So, if a customer takes an EMM from one engine to another, it is effectively a modification.
Also, they absolutely do not want two EMMs with the same serial number floating around out there.
All kinds of different scenarios are possible if they had this EMM software where it could be modified.
Right now they have it pretty well pinned down. The program is protected with a checksum. Any bit that is changed, the checksum will not match.
The injector coefficients are in a data file that has been encrypted....there is no man-readable information in there. So, you cannot open the file in a binary editor and make changes. You would not know what to change.
I was "lucky" (I guess is the word) enough to work with a guy a couple of years ago where we hacked the older FICHT EMM software. We were able to successfully write the 175 engine map to a 150 EMM. His original engine ID, hours, etc. were still there, but it had a 175 map, and was putting out 175HP, even to it was badged as a 150.
Cannot do that now on the ETecs. Or at least the backyard guys would have a very difficult time.
But you can absolutely take a working EMM and put it on an engine with a dead EMM. You will not be able to change fixed parameters like engine serial number, and every time it goes to the shop, Evinrude techs will read out inaccurate engine data on the engine report.
It will work, tho. You must be sure to put the new injector coeffiecients in the replacement EMM.
That is a discussion for a different thread....
