DayCruiser
Ensign
Thread starter- Joined
- Sep 24, 2004
- 953
1990 Merc Cruiser i/o 130hp 4 cylinder<br />Plugs 1 year old<br />PLug wires new--bought this past weekend to try and eleviate the problem. Guages show no other problems<br /><br />Ok when starting out the boat starts right off and then runs smoothly for a couple of hours.<br /><br />Then when shut off for a swim it is hard to start. To the point of almost running down the battery. I have found if I take the carb cover off and fiddle with the flipper thingy in the carb--then the boat will start. I have done this a couple of times with success. But the boat runs rough after that and then tries to shut off when slowing down to go under bridges and then sometimes just shuts off when docking. THis last time after I put the new spark plug wires in it didnt shut off when docking. But it was still very hard to start after the second shut off.<br />I have a water seperator that was checked a month ago and it showed no signs of water.<br />Seems that after the motor heats up the problems start. Runs at 140 degree's average.<br />Vapor lock or what? This can be unnerving as we all know. How to I remedy? Carb shows signs that its getting plenty of gas. I run Shell V power 89 octane. Should I lower the octane to 87?<br />Thanks in advance!
