1972 Evinrude 25 bad backfiring
1Dollar
Working on getting this 1972 Evinrude running. I got great help on my 1st question, much appreciated!
This is an electric start model and I've gotten it running but never for longer than 30 seconds. I believe I have an ignition timing issue as I am getting STRONG BAD backfires intermittently. They splash water out of the barrel 10 feet. I got it to run the best when I unhooked the timing plate/carb linkage and manipulated them manually. It was hard to do but when they are hooked up I get the backfiring wither during cranking over or within 10 seconds of the engine starting.
Can someone describe the timing or any link n sync procedure for this engine? I've got the points set to .020" and spark is a brilliant blue. I'm new to outboards but have some antique tractor experience as well as autos.
Thanks
boobie
Is the breaker point cam in time with the crankshaft ??
1Dollar
I guess I thought the breaker point cam was part of the crank, as in they're the same piece of metal. Is it a keyed or pressed part on the crank? How can I determine if it's in the right location?
Use a timing light on the 2 vertical marks on the magneto plate.--------The mark on the flywheel should be between the 2 marks.
boobie
If indeed this is a '72 25 the parts book shows the cam separate from the crankshaft. Post a model #.
1Dollar
It is a 25252R if I recall correctly just sitting here. I bought a service manual that should be on its way.
I do not have a timing light, is there another way to do it? I can hardly get it to run long enough to do active diagnostics anyway.
Thanks
Chinewalker
Could the cam be upside down? Would affect timing. Also could be wrong cam, or wrong flywheel. Flywheels & camsfrom later models look similar but have different magnet arrangement for the low tension magnetos. Your's has the standard magneto with the coils under the flywheel. If the throttle arm and linkage are original to the motor, there isn't a whole lot to do beyond gapping the points at .020" to set the timing.
