Johnson seahorse 25hp 1974 or 75 help please!
Dbill27
I've got a Johnson seahorse 25hp model # 25r74m, serial number e4018676. Anyways I just got it, didn't and don't know anything anout boats or outboard engines so of course first thing I did was start it up dry a few times. Come to find out, that's not such a good thing. So I'm assuming it needs a new water pump. Anyone have any advice in where in the hell to find parts like that for something this old and then also instructions on how to fix something like that? Any and all comments or thoughts are greatly appreciated
That motor is not considered old in many places.----Most good BRP/ EVINRUDE dealers will have or be able to get the parts !
jasper60103
If it looks in decent shape, its probably been well cared for.
Getting your hands dirty is part of the game of buying used outboard though.
Common wear parts are available from your local dealers or online.
Plenty of used parts to be had at marine salvage yards, ebay, CL, etc.
A OMC service manual would be helpful too, and can usually be found on ebay.
Good luck.
-jasper
gm280
You 25HP Johnson is indeed a 1974 model. And there are lots of OMC parts still available for it. You can even go to iboats (no here) for parts and if you want to see a break down of every section about your OB, go to boats dot net and search in the Johnson engine section under the Model Number or Horse Power or even the Year (1974) and select your Model Number from the available options and you can see everything concerning every section of your engine.
steelespike
It's a good choice Easy to work on and plentiful parts.
Don't remove the phillips head screw from the gear case.
The motor is 22 cu. in. It is a really light 25.Basic motor started out in 1957 as a 18 hp.
A compression check will help tell the condition.
Drain the gear case note the condition of the lube water/rust metal filings.
Changing the impeller is a good thing on an unknown motor.
