18hp evinrude over reving
Merklin
I have an 18hp evinrude, not sure of year. It starts and runs great. My problem is when I put it in gear (forward) it over revs at fast speed. Tried a brand new prop and had the same results. In other words the engine runs but the boat does not get all the power to the prop due to the over reving. Any thoughts about why this is happening?
flyingscott
spun hub in the prop or broken drive pin take the propeller off and check the pin.If that is good on the backside of the prop scratch a line across the hub and the edge of the prop and run it. After it does it again take it off and check your line if it moved the hub is spun.
nwcove
op says "tried a brand new prop"
Merklin
nwcove do you know the difference in the length of a short shaft and a long shaft?? I think you are right about the transom size. When I run the motor on the boat lift, it goes like the dickens. Then I try it on the lake it over revs. I do have it on a deep transom boat. A boat that I think now has to be remodified. How much then would I have to remove from my transom to make this motor work for me?
Merklin
I am sure it isn't the prop. Both the original and the new prop acted the same way on the lift and in the water.
F_R
Difference between long shaft and short shaft is 5 inches. Long is 20", short 15". Actually, those numbers are obsolete, and boats today generally are a bit taller than that. At any rate, if you do have a short shaft motor on a long shaft boat, don't butcher the boat by cutting it down. Put a long shaft extension kit in the motor instead.
Merklin
Recommendationa as to where to look for an long shaft extension kit? Cost of kit?? I could do the work myself.
steelespike
Ebay is probably the best source for a quantity of parts.I did a brief check for asking prices.
Shift rod extension $40, Leg extension $68. You need a drive shaft,shift rod,leg ext., water tube
I think your better off to sell the 18 and get a motor with a long shaft.
By the way the 18 eventually evolved into 20 and 25 hp.At 22 cu in., prior to 77. One of the lightest 25s made.
I like the early Evinrude and Johnson motors,easy to work on, an amazing availability of new and used parts.
