Thanks guys!
I see where it needs to go now! I'll certainly pull the starter to gain a little more space, great idea racerone!
I decided if I have to go ahead and pull the carbs they should just be rebuilt for peace of mind in this process of elimination trouble shooting. I ordered the kits here on iboats for $16 each but have never done a rebuild job. I found a pretty detailed video here:
https://www.youtube.com/watch?v=FkhyS83s_XY
The guy has a 1983 50HP which is the exact same carb so it is super helpful.
Now... Is there any info here on actually removing the carbs and linkage? I sorta see a pin holding it in place, but not sure how it all comes apart and most importantly goes back together. Hopefully the kits arrive by this weekend.
I ran the engine this morning just for the fun of it before doing the carbs and took a video. It didn't want to start but eventually after finally getting the bulb firm on the fuel line it sputtered to life and warmed up to idle quickly. I assume the carbs were just dry. It ran for about 5 or so mins and then would almost die and come back. I shut it off and put it away after that happened twice. I'm not even sure if the motor sounds healthy lol. Take a look at the video and let me know what you think.
Small issue next. My fuel tank is also leaking at the connection and sometimes at the motor connection. It was feeding the motor better once I had the tank up in the splash well. I am shopping for a new hose with connections now, but when I installed the two prong connector in the plastic tank should I have used teflon or some kind of thread compound?
Anyway, thanks again guys!
