1988 evinrude tilt/trim issue
lampe176
I am having problems with my tilt/trim it works fine but going down the lake it will trim down but not up you take the load off of motor it will trim up having no problems trimming down. It works fine just sitting still or out of the water. I have check the fluid level and it seems to be fine. Any suggestions on what would be next would be great. thank you Larry
Fed
Model Number?
Not designed to hold against tilt only against trim so if it's in fact the tilt coming down rather than the trim then that's normal.
