lower unit bolts
joe johnson
i am wondering if its ok to switch out lower unit bolts to steel i striped a few of the original bolts on removal and do not want to deal wit that again
TwoRivers
Which bolts on which motor are you speaking of? The bolts that hold the lower unit to the mid section are steel on my motors.
F_R
Actually, they should be stainless steel
With stainless bolts you get the white powder which is aluminum oxide.---With carbon steel bolts you would get the aluminum oxide + the brown powder wich is iron oxide ( aka rust ) in there.---Makes no sense to use anything but stainless bolts.
TwoRivers
I thought the OP may be speaking of aluminum bolts as stainless bolts are steel bolts?
They have never ever installed lower units with aluminum bolts !!
joe johnson
Im speaking of the bolts that hold the lower unit to the mid section im second guessing because i got to thinking if i put steel bolts into aluminum wont it cause electrocis or if i end up hitting some thing wont the harder steel bolts mess up my midsection were they are bolted too
joe johnson
Well this is my first boat and maby someone else has put the aluminum bolts in their so it dounds like it is a good idea to use the stainless steel bolts i was just under the impression that you are not supposed to have steel and aluminum bolted together
Stainless steel bolts into aluminum threads is not a great combination. I am not sure why Johnnyrude uses them. Put some permatex aviation or # 2 sealer on the threads of the SS bolts when you reassemble.
Mercury uses stainless steel studs into the gearcase and midsection. Stainless steel locknuts are then used on the stainless steel studs. I have never has an issue with the nuts getting corroded.
