bruceb58
- Mar 5, 2006
- 30,798
What do you mean by nicer and cleaner? How is that better for a bulb that sits behind a red lense?They use LEDs because they give nicer, cleaner,...
Exactly!Light behind lenses, is light behind lenses. When looking at LED's I look at color temp, of course if I am going to put it in a tail light, I could really care less, as long as it is bright enough for someone behind me to see.
OP asked about the requirement for a resistor to be used with a flasher unit. Here's the answer for THAT question. If it's an older 'non-electronic' flasher, then yes, it will require a resistor in parallel with the LED (not series) so the flasher unit 'sees' the correct load, or it will flash at the wrong rate.
I know I would like to convert the boats interior lights to LED, they have the old 1156 or 1157?? (Bayonet fit with single element)
I would like the LED bulbs to fit into the OEM light fixtures if possible, so I need to do some home work.
(how about fluorescent 12VDC fixtures that don't cost an arm or leg and are reliable??)
The reason new cars use LEDs is because they are cheaper and they can run less wire(less weight). Only one wire is required to operate a brake/running light because they just PWM the signal going to the bulb to create bright or dim.
Another reason is they can now make odd shaped light housings and be able to illuminate evenly where before they would need multiple bulbs.
There is a huge push by auto makers to reduce the weight of the car. That is why ethernet in the car is the next push. The company I work for makes test equipment for testing automotive ethernet.
Yes, I agree that this is a big safety advantage of them.Another advantage of LED brake light s that I don't think was mentioned is the faster illumination time. That fraction of a second warns following drivers a tiny bit sooner so their reaction should also be a tiny it sooner. A couple of feet can make the difference between a near miss and a collision.
Are you color blind or something? Look at a (good quality, DOT approved) LED taillight compared to an old bulb. The LED will have a better color of light, that will shine crisply and clearly through your lens. Not only is this more aesthetically pleasing, it makes it so other drivers can see you better. There is no comparison between the two. the light that comes out of an incandescent bulb is not the same!What do you mean by nicer and cleaner? How is that better for a bulb that sits behind a red lense?
