'81 johnson 35 water issues
tnmedic82
So I'm brand new to owning a boat. Have fiddled with other small engines and larger engines, but never owned a boat. So I bought a boat, 14' glassmate fishing boat, put muffs on it and it had water coming out the telltale, and spitting out the 2 (exhaust?) holes. So we took it out to the lake to try it out. Starts fine, runs fine. But after we had ran it about 10 minutes (max speed 10.8 mph via gps) at full throttle you could hear a change in pitch in the engine and it started to slow down a little. So we turned around and started back, it was sounding weird, and on a whim I pulled out the choke..... It actually started running better (18 mph via gps). So we ran it up and down the lake a few minutes like that, but I knew something wasn't quite right so we went back to the ramp. As I was loading the boat, the motor quit and it was hissing steam out the 2 holes. I started it back up for a sec and it did the same. So we put it on the trailer and took it home.
Reading a lot of threads on here led me to believe it might be the impeller, so I took it apart and the impeller is fine. It is pumping water, (don't know if it is adequate amount). Checked the water tube and it sprays water out of the telltale really good. So then decided to check the thermostat. Got it off and put it in a pot of water on the stove. It opened at somewhere between 140 and 150 degrees. Put that back and started her up.
Decided to use a trash can of water rather than muffs. It sprayed water out the telltale and then started spraying water out the 2 holes. After a few minutes running it at various speeds it stopped spraying water and just started steaming/smoking out of the holes and telltale. The housing got really hot, so I shut it back off and waited for it to cool down.
After an hour or so, ran it again and it sprayed water consistently at all speeds and for about 20 minutes. The housing never got hot this time.
Let it cool down and started it back up, it now is not spraying water at all, just smoke/steam out of all the holes. So I didn't run it long like that. The housing was getting hot.
So it works one time and the next it doesn't. Does this sound like the impeller? Or might it be something else. I would think if it was the impeller it would either work or not work. I have a video of it running if that would help
Thanks for your help
For many years I have said -------" whenever you buy an outboard motor the first thing you do is install a new impeller "-------Hopefully it is not too late on your motor !
Bosunsmate
Your water level in the bucket probably got lower than halfway down the leg (which is where the water needs to be at when the motor is stationary as it has no forward pressure to push water up to the pump) and so your impellor burnt up
tnmedic82
no, the water level stayed to the very top of the trash can. I had a water hose running in it the entire time. But i guess I'll buy a new impeller to see if that changes anything. I just thought with it being pliable and still pumping water that it was fine. Thanks.
btw any thoughts on why it was running better with the choke out?
bonz_d
This is interesting, never hear of one acting like this. Post back what you find.
bonz_d
Looks normal to me. Is that all you did to it was change the pump? Did the impeller fail?
tnmedic82
no, the impeller looked fine. I went ahead and changed it anyway. We'll see how she does on the water. Hopefully the weather will clear up enough to take it out Tuesday.
