1981 evinrude 115hp no power. Please help
Lukef
Just fresh water use. Ill order the gaskets tonight. do you think some JB weld would hold up?
Bosunsmate
maybe the high heat one... im not sure,have a poke around when you have the exhaust gasket out, see if you can put a paperclip through it, for water to of made that crack it will be big enough on the inside to poke a pin through
Lukef
I used this for reference 16.png [h=2][/h]
#Part NumberDescriptionMSRPPriceRequiredQty
Price is for one part. We sell all parts individually.
10389606CYLINDER C'CASE ASSY, 115$0.00$0.001NOT AVAILABLE
10389548CYLINDER C'CASE ASSY, 140$0.00$0.001NOT AVAILABLE
10389912CYLINDER C'CASE ASSY., 90$0.00$2, 992.851
20304178PIN, Dowel bearing$4.99$4.041
30318562WASHER, Stud$11.00$11.001
40321640STUD$12.99$10.532
50310507PLUG, Oil hole$4.99$4.041
60314616STUD, Cyl. to lower unit$15.99$12.962
70308752SCREW, C'case to cyl. bottom$4.92$4.922NOT AVAILABLE
80318907SCREW, C'case to cyl, top$5.90$5.902
90305070PIN, Taper$1.99$1.612
100322986STUD, Throttle lever$27.88$27.881
110319592SCREW, Lock plate cyl. to c'case, center$7.99$6.472
120322411DEFLECTOR, Water pass$4.99$3.524
130300646SCREW$4.99$4.042
140306778SCREW, Cylinder to crankcase$4.99$4.046
150316286SCREW, Spark adjust$0.00$6.471
160202026WASHER, Shift lever$4.99$4.041
170552906COTTER PIN$0.99$0.701
180307133GASKET, By-pass cover$2.99$2.114
190390449COVER, By-pass$20.00$20.003
200390450COVER, By-pass$20.00$20.001
210304753NUT, Screw, spark adjust$0.00$2.471
220321886ELBOW, Indicator$2.99$2.111
230303480LOCKWASHER, Ground strap$0.00$0.704
240376349STRAP, Ground$8.30$8.301NOT AVAILABLE
250306049SCREW, By-pass cover$4.99$4.0419
260326372PRIMER DRAIN HOSE GUARD$0.42$0.422NOT AVAILABLE
270318358GASKET, Cyl. head$24.99$17.612
280326505CYLINDER HEAD, Stbd., 90, 115$192.75$192.751NOT AVAILABLE
280326503CYLINDER HEAD, Stbd., 140$225.80$225.801
280322865CYLINDER HEAD, Stbd., 140$0.00$225.801
280324529CYLINDER HEAD, Stbd., 90, 115$0.00$0.001NOT AVAILABLE
290318335GASKET, Cover$3.99$2.822
300318333COVER, Cylinder head$68.30$68.302NOT AVAILABLE
310309322CLAMP$0.00$0.805
320306409SCREW, Cyl. head cover$4.99$4.0432
330307267SCREW, Cylinder head$6.99$5.6620
340386939SPARK PLUG, Ac m40ffx, 90, 115$0.00$2.244
340384771SPARK PLUG, Ch ul-77v, 140$10.99$7.754
340386941SPARK PLUG, Ch l77j4, 90, 115$3.17$2.244
340387633SPARK PLUG, Ch ql-77j4, 90, 115$0.00$3.824
340387239SPARK PLUG, Ch qul-77v, 140$0.00$7.754
350386686SWITCH TEMP$71.63$71.632NOT AVAILABLE
360303806SLEEVE, Switch lead$8.15$8.152
370321724HOSE, Cylinder head, stbd.$0.00$15.491
380321723HOSE, Cylinder head, port$0.00$13.771
390324825CLAMP, Cylinder head hose$0.99$0.704
400322864CYLINDER HEAD, Port, 140$0.00$334.101
400326502CYLINDER HEAD, Port, 140$412.47$412.471
400326504CYLINDER HEAD, Port, 90, 115$192.75$192.751NOT AVAILABLE
400324528CYLINDER HEAD, Port, 90, 115$0.00$0.001NOT AVAILABLE
410322684FILLER BLOCK, 115, 140$17.00$17.004NOT AVAILABLE
420322858GASKET, Water passage cover$1.99$1.411
430318473COVER, Water passage$34.00$34.001
440308742SCREW, Water passage cover$3.05$2.476
450326642LEVER, Shift rod$46.00$46.001NOT AVAILABLE
450318539LEVER, Shift rod$0.00$46.001NOT AVAILABLE
460317914GASKET, Exhaust cover, 90, 115$9.99$7.042
460317955GASKET, Exhaust cover, 140$13.99$8.871
470325857SCREW, Lever$5.00$5.001NOT AVAILABLE
480308751SCREW, Sprt brkt to by-pass cov$0.00$4.044
490323468EXHAUST MANIFOLD, 140$432.42$432.421NOT AVAILABLE
490322689COVER, Exhaust inner, 90, 115$96.41$96.411NOT AVAILABLE
500323335HOSE, Indicator, 90, 115$3.06$3.061NOT AVAILABLE
500323320HOSE, Indicator, 140$4.07$3.301
510390015COVER, Exhaust manifold, 140$149.99$121.611
510323153COVER, Exhaust outer, 90, 115$0.00$0.001NOT AVAILABLE
520323469GASKET, Exh. manifold to cyl., 140$9.99$7.041
530309905SCREW, Exhaust manifold to cylinder, short$4.99$4.040
530308728SCREW, Exhaust manifold to cylinder, short, 1 40$5.09$3.9416
540204046NUT, Throttle stop$0.00$3.301
550312708BUSHING, Shift lever$3.99$3.232
560120356COTTER PIN$1.80$1.801NOT AVAILABLE
570306396LOCKWASHER$9.17$7.431
580323089SHIFT LEVER$60.00$60.001NOT AVAILABLE
590305981WASHER$3.84$3.841
600315101BUSHING$4.07$3.301
610323264PIN$5.99$4.851
620554427NUT$0.00$4.963
630389882LINK & PIN ASSY.$0.00$0.001NOT AVAILABLE
640316602SCREW, Throttle stop$3.96$3.961NOT AVAILABLE
650314125BUSHING, Link$6.11$4.961
660323267PIN, Lever to rod$0.00$6.611
670314515SCREW, Bracket$3.99$3.232
680315104RETAINER, Rod spark adv.$9.00$9.001
690315182CLAMP, Motor cable$22.44$18.191
700306547WASHER, Spark advance rod$1.25$1.252
710323898LIFT BRACKET$19.41$19.411
720303304WASHER, Ret. spark adv.$0.00$4.041
730308993SPRING, Idle adjust$4.99$4.041
740203688NUT, Idle adjust$3.99$3.231
750132942SCREW, Idle adjust$0.00$6.471
760318561LEVER, Spark advance$14.91$14.911NOT AVAILABLE
770322549RETAINER 90, 115$26.52$21.501
780386588THROTTLE CAM ASSY.$0.00$17.001
790310928CLAMP$3.99$3.231
800305650COTTER PIN$0.99$0.705
810310524YOKE, Throttle cam$12.00$12.001NOT AVAILABLE
820387956LEVER, Throttle$0.00$35.001
820391936LEVER, Throttle$35.00$35.001
830318660CAP$5.09$4.121
840315081BUSHING, Throttle lever$6.11$4.961
850317972SCREW, Exh. manif. to cyl., 4-1/4" lg. 140$15.30$12.411
860318560BUSHING, Spark lever$25.00$25.001
870322987WASHER, Throttle lever$2.50$2.501
880314094SPRING, Throttle lever$15.30$12.411
890321726ROD, Throttle lever to cam$0.00$12.971
900314136SCREW, Throttle cam$7.99$6.471
910314137BUSHING, Throttle cam$0.82$0.821NOT AVAILABLE
920204445WAVE WASHER, Throttle cam$12.00$12.001
930204757SPRING WASHER$4.99$4.042
940302474WASHER, Link$4.99$4.043
950319217SUPPORT BRACE, Port$15.00$15.001
960319218SUPPORT BRACE, Stbd.$16.55$16.551
970313581BUMPER, Support brace$6.11$4.962
980306375NUT, Lower by-pass cover$0.00$1.651
990313700SOCKET, Linkage$0.00$5.411
1000313703BALL, Socket linkage$0.00$5.411
1010327338ROD, Spark advance$0.00$15.001
1020320396NUT, Shift lever to crankcase$0.00$4.041
1030320397WASHER, Stud$4.99$4.041
1040311328BOLT, Double end$0.00$6.611
1050314416BUMPER, Screw$6.11$4.961
1060302290LOCKWASHER, Pin$0.99$0.701
1070326365SPRING CLAMP, Cable to brace$8.99$7.281
1080306561WASHER$0.00$3.232
1090317952SCREW, Cover, 140$0.00$1.411
1100303311SCREW, Clamp to brace, port$3.06$3.061NOT AVAILABLE
1110310439CLAMP, Water passage cover$4.99$4.041
1120303459SCREW, Exhaust manifold cover, 140 only$5.99$4.852
1130392000EXHAUST FILLER BLOCK REPLACEMENT KIT$182.47$182.471NOT AVAILABLE
1140389187LOW COMPRESSION CYLINDER HEAD KIT$0.00$0.001NOT AVAILABLE
1150391300POWERHEAD GASKET SET$0.00$118.511
Lukef
I ordered the exhaust manifold gasket and cover gasket tonight. I'll report back when I have a chance to do the install. As for the exhaust port blemish, I'm looking for ideas?
emdsapmgr
Be careful when ordering the gaskets for your engine. The pictured block is the bubble back 135 version and shows two different exhaust gaskets. Your flatback version is not pictured. You will need 2 pcs of the original part number: 317914. When you get the inner exhaust cover off, test it. Lay it perfectly flat. Pour some water on it. Let it sit for 10 minutes. If any leaks through, you've got a hole in the cover. You can repair any hole by aluminum welding it. (An unusual failure, but test it anyway as long as you have it apart.)
Lukef
I order two gaskets (317914) and one gasket (323469). I cross referenced all the parts before ordering them. I may end up with an extra but better safe than sorry. I hope this works or I'll be looking for a new engine.
V153
well. i changed the head gasket and im still getting milky sludge on one plug
Sounds to me like you need to have that head decked. What's the compression in that cylinder now?
Looks like the "hole" in the exhaust port is just a void in the casting. If you must, fill it with marine-tex.
Are you tightening the head, incrementally, using the correct sequence? For future reference:
Dunno how this matches to in/lbs but spec I got is 16-18 ft/lbs for the exhaust housing.
Lukef
I torqued the head in two incraments. First 10 ft lbs, then went to 18ish. I did do it in the proper sequence. 16 ft lbs sounds like way to much for the exhaust cover. 60-80 inch pounds is the spec I got and that is about 5.5 - 6.5 ft lbs. Head is straight but just in case I planed it on a piece of glass and used some 220 grit sand paper. The exhaust manifold gaskets are on the way but I have a sneaky suspicion that the imperfection/crack in the exhaust port is to blame. Their are water passeges on the back side of that crack. I don't know exactly where but their there. Where can I buy that marine-tex at? The compression on the problem cylinder was 135lbs. All others were 120 lbs.
emdsapmgr
Not sure marine tex is the correct solution. Great as it is, it may not last in this high-heat environment with lots of heat and cooling in that area. Try running it after replacing/torquing the exhaust gaskets first. What does the inner exhaust manifold look like? Best to re-torque that manifold (and head) after the engine goes thru a couple of heat/cool cycles.
Bosunsmate
If you remove 42 and 43 in that diagram it might be from the bottom of that water closet
V153
Try'n pour or poke or squish somethin into the void to see if it passes through.
That gasket's an easy one to make btw ... (You said you were cheap ...)
