1972 Johnson 85 HP Backfires
cardoctor71
I have an old 1972 Johnson 85 hp that has been sitting up for about a year I have spark,I have fuel ,but I also have a violent backfire through the exhaust,it ran fine before sitting up,can anyone shed some light on this issue,what to look at first?
Bosunsmate
Clean all the carbs, blow compressed air through every hole, or carb cleaner, all of them must be clear, even a tiny hole thats blocked can cause a violent backfire.
Fuel that sat for a year in the carbs gums them up and causes that
GA_Boater
Welcome aboard
Started a new topic for you because the one you posed this question is old, inactive and not related to your problem.
SparkieBoat
If it is not running but you only get the backfire, my guess would be that the flywheel key is sheared. Also clean your carbs like the post above said.
A sheared fywheel key may not affect the timing on this engine.
JRegier
I had a similar problem with my 1970 115 'rude. My flywheel had come loose and though the key was alright and I torqued it back down, there's a plastic rotor under the flywheel that has a notch in it to keep it where it needs to be and the notch had sheared off on mine. That would be the first thing I'd check.
boobie
It's a battery CD model and doesn't require the flywheel to be in time. All timing comes from the crank shaft.
boobie
Check your distributor cap and rotor for any carbon tracks. Had it happen.
SparkieBoat
dang.. i forgot those old motors had distributors...i hate distributors on an outboard...I usually do not mess with anything older than 79...then his problem is most likely distributor related.
