Onexl85
Thread starter- Joined
- Jun 17, 2014
- 203
So today I picked up a 97 bayliner 2355 cierra. We ran the 5.7 on muffs. Question is do I have to run antifreeze thru it again? Here in Ny 12533 the temp tonight will reach 22 for a short time. As a precaution I removed the petcocks to drain, then I removed the largest and seconed largest hose off the thermostat housing and forced antifreeze thru them, should I be ok? temp will be in the 40-60 range from here on out it looks
Thank you
Bill
Thank you
Bill
