2006 Johnson 150hp trouble shooting
Manateehunter
I have a 2006 Johnson 150hp carbureted outboard on my bass boat. Long story short, it's been sitting for 3 years. My oil tank had about two qrts of ice in it so I removed the tank and cleaned it out. The gas I'm sure was stale so I removed it all and got new gas today. I ran a small gas can with sea foam through the motor, let it sit a while. Then a second time. Installed new fuel water separator. New fuel lines. I ran the motor for about 20 minutes with new gas( had to keep restarting due to stalling)....no sea foam and it misfires like crazy and smokes a ton. The smoke doesn't seem to go away. It's a blueish smoke that lingers. The motor misfires a lot aswell. The spark plugs seem fine. What should my next step be? Clean the carbs? Can dirty carbs cause excessive smoke and misfire? Or is my fuel/oil pump bad? Thanks
Bosunsmate
Have you put the plugs on the right cylinders? Checked timing?
Id clean the carbs too, not likely to cause excess smoke but very likely to cause misfiring. Since you have just swallowed seafoam down it then it would be likely to excessively smoke until its running properly with fuel in all cylinders
crazy charlie
Do a compression test first and check that the proper wires go to the proper plug.Seafoam will make it run with a lot of smoke depending on the concentration.Try running with gas oil mixture and bypass the res oil tank.Charlie
boobie
Seeing it's been sitting for three years, take it out and run the hell out of it and see what happens.If it doesn't want to get full power, slow it down and find out why.
reiddo1
Ditto to the above but I would be very suspicious of an oil tank full of ice and what prolonged effect that has had on the oil mixing system. When I used concentrated Sea Foam on mine it took quite a long time for the thick smoke to subside. The previous owner/s of mine removed that mixing tank system so I at least have any doubt removed as to whether it mixes properly. This is a rock solid engine which in normal operation on start up smokes a fair amount and also likes fuel but with good compression, good fuel/carburetor and good spark/timing will run head to head with any 150 hp made! Good luck with it.
Gee, you have some real challenges. Because of the ice in the oil tank, I am real concerned about the rest of the motor. Squirt some oil into the cylinders and check the compression. If that works, clean all the carbs. If she has spark, I would run a 50::1 gas oil mix for the duration of the troubleshooting.
Get the motor operating properly on the gas/oil mix. That includes timing, mixture and cooling.
Clean out the oil lines to the VRO. Say a prayer for the VRO. Bleed the VRO. Run the 50::1 mix until the VRO is working.
